Hi all,
When I make a melody in a midi clip using a sound from the Moog, there’s no sound coming from that midi track.
Anyone else having the same issue?
Hi all,
It looks like you didn’t set your midi ports correctly. Check into this first.
Hi Gil,
The midi ports were set correctly. Looks like it only works with the External Instrument option and not the VST by itself on the midi track. It would be awesome if it could in the upcoming release.
Many thanks,
This is expected behavior; the editor plugin is not intended to replace the functionality of an external instrument plugin. The intended use is to put the editor as an “effect” on the channel which is hosting the external instrument plugin.
If you set it up as described above, do things work OK for you?
thanks!
Hi Amos,
Yes, it works that way.
