Putting some external sounds through my Voyager and it sounds like something out of sci fi film, what is going on? The Voyager is attacking the external noises with a laser… I am somewhere in the moogerbar system.
Yes, and be very careful not to look directly into the left/right output jacks with nothing plugged in, cause you WILL be blinded!
What kind of visor do you recommend?
You have to use a genuine Moog visor.
Apparently, the filters are simply not good enough with other manufacturers.
OK, I won’t engage the sheild is too strong.
they have to be genuine Moog Music visors as well, Scotty set it up so that knock offs won’t work!
The Korg ES1 is interesting as an effect unit attached to the Voyager, put the BPM to warp factor 300 and Scotty will soon belt up.
