How do you make a longer note on a single stage of the 960, or is it not possible,
or do you have use the Timing on the B-column of the 961 or use the envelope?
I’m a bit stumped with this one!
depending on your intent:
you can use ‘3rd row control of timing’ to adjust sequence step period;
or, a 962 analog switch and a 961 to switch between two B-col delay settings.
