5/4 Taurus 2
all sounds by Taurus 2 and B Murf
exept claps by Clap Trap
http://youtu.be/1yYB_iovlsk
cool stuff :slight_smile:
Great seeing T2 in action; it’s a forgotten synth, the Rodney Dangerfield of the line right next to the Opus 3 but you gave it the respects that it deserves.
Good show as usual and great visuals.
Ebo,
I was wondering if you got into the video synthesis euro modules or is that next?
Thanks everybody !
for this vid I only use a Midi to CV Interface and Logic for Sequencing ,no €rack.
but the Taurus 2 works well with the €rack (1v octave and a normal Trigger)
the only thing I miss a Filter CV in for the Taurus 2.
for the video I use I movie
Hi Fans! We have a band called Afterglow/Finland, with 3 different Rickenbacker players and Two Moog Taurus II Bass Synthesizers. -We discovered maybe a solution to all having problems with the synth getting out of control at stage: First causing the problem and second, how to eliminate: Light works/control at stage sending a lot of electromagnetical noises and if U have a standard MIDI cable between the control unit and the pedals, this is the problem, which making problems for at the gigs. Normally the midpoint of the 5 pole cable is connected to shield and that is the problem. -Just use cable with the shield NOT connected to mid pin, or prefeably, connected separatelly. -If You use a shielded original cable, do not forget using the “Pole” as grounding! NEVER EVER USE STANDARD MIDI DIN CABLES! And it may work better…
The T2 is a synth-Stradivari. Obviously no-one dares to admit this. Those who have one should compare theirs to their other synths more carefully, and they’ll find out too :smiley: .
