105m send clock?
Does the Murf send clock or just obey midi clock?
Also wanted to know if there was an Apple AU or VST plug in for it or just the stand alone app?
Without a MIDI out, could it send a clock signal?
Not sure if your reply is constructive or sarcastic but I’m guessing that it only has a midi in? Do they make double use of it as done on some of the CV jacks?
Not sarcastic. I’m pretty sure the Midi MuRF only has MIDI In. I honestly don’t know if signals go both directions - they certainly could, but I don’t know how things are implemented. Most devices that send MIDI have a dedicated output for that.
There is no clock out on the Midi MuRF. The Midi is input only (as far as I know). In fact there isn’t any CV outputs at all (besides voltage for the pedal inputs).
It would be awesome to have a switch on it to change it from midi in to midi out. Or use the 2 pins in the cable that aren’t used to allow a “Y” cable to hae both in and out. That way you could record knob tweaks and pattern changes.
