Quick Query. The 104M manual lists MIDI time clock divisions for the LFO but not for the delay. Is there a way to divide the delay as well? Cheers!
Hi FourLegsGood:
If you’re sending the MF-104M MIDI Clock from an external source, you’ll first need to send a Start Message from your external device.
Once you do that, you’ll see that the TIME and RATE LEDs are now orange. The TIME knob and RATE knob each choose a unit of the beat for its parameter.
The Clock Division values for Time Clock Divisions is the same for LFO Clock Divisions.
Thank you! Am I understanding it in that the time clock division must be set from the TIME knob and cannot be set from a CC message?
All I know is that such a CC# it is not printed in the manual.
I don’t have time at the moment to try every possible CC#, so I’ll see if anyone at Moog knows if there is one.
Should be #90 / #107 (for TIME / LFO respectively). The same clock division table should apply.
It’s not in the original manual from 2 years ago but the Super-Delay supports this and there is a noticeable gape following #89 in the original manual so could have been a bad edit job.
If indeed this is not supported on the 104M, then they dropped the ball
and it’s time for a firmware update and a doc addendum.
Hi Everyone,
Andy from the Moog Tech Support Dept. here!
Just to let you know, all of the features on the 104M and the 104M/SD are essentially the same, except for of course the longer delay time on the SD.
There has been an addendum added to the download page for the manual which includes all of the current feature set for both products:
http://www.moogmusic.com/sites/default/files/MF_104M_Addendum.pdf
Thanks,
Andy Hughes
Service Department Manager
Moog Music, Inc.
