What moog shall i get? I need everyones input.
The synths I was looking at were the...
1.) Moog/Realistic MG-1 - Isaw that you could make violin sounds and footsteps and stuff,but it doesn't seem like a real moog to me.
2.) Moog Prodigy
3.) Moog Rogue- Because the Keyboardist from Thursday( my fav.band) uses it.
4.)Moog Opus -3
With all these synths could I achieve the same sounds out of all of them, like an violin,cello, and some other werid stuff.
Thanks for all your help
Which Moog?
A few places you can look are http://www.sonicstate.com/synth/cfman.cfm?manid=23 and http://www.synthmuseum.com/moog/index.html. They have links to specs, etc., and may help describe the differences between the various Moogs.
Don't expect a portable analog monosynth to be able to mimic every instrument. You may be able to get some instruments really close, but a synth is its own beast and creates its own types of sound.
IMO, no matter which Moog you settle on you will have endless enjoyment.
Well, first off, the rogue and the MG-1 are almost exactly the same synth, so dont discount the MG. The only differences are: (1) the rogue has a pitch wheel, the MG doesnt (2) The MG has a polyphonic section, the Rogue does not (3) the MG has both RCA and 1/4" outputs, the rogue only has 1/4" (4) generally speaking, people have been paying more for the Rogue then for the MG-1 just because the MG says "realistic" on it instead of "moog", but rest assured, its all moog innards. its fully a real moog synth.
Next, the Prodigy is a great synth and more versitile then the mg/rogue, but it'll cost ya probably an extra 200 bucks over the MG.
Lastly, the Opus 3 is a string/brass/organ polyphonic synth. For what you seem into i wouldnt go with it.
I'm a fan of Thursday too, and I own an MG-1. For someone just breaking into synths, the MG is really a great start. The prodigy could be a bit too much for someone just starting, and the rogue is virtually the same instrument but costs more and has no polyphonic section. For my money, i'd go with the MG-1. Good luck!
What about the Micromoog?
When speaking of the less expensive Moog monosynths, it seems like people merely consider the Rogue or the Prodigy. While having two oscillators is nice, there is a HOST of unique and exciting functions provided by the Micromoog. Apart from the fact that it is single oscillator, it is a far more interesting machine than either the Rogue or the Prodigy.
The fact that the Prodigy is often more expensive than the Micromoog is totally baffling... I guess you're paying for that extra oscillator, and the extra envelope control. In any case, snatch up a Micro, you'll be glad you did.
www.youtube.com/user/automaticgainsay
www.myspace.com/automaticgainsay2
www.myspace.com/godfreyscordialmusic
