Hello Everybody,
Since I have my Matriarch hooked up to an Axe FX I never realized how
noise the delay cuircuit of the Matriarch is. I don't know if that's an
issue with my unit or just the nature of the design.
I was wondering if anyone could confirm that this is indeed normal
or a faulty module. Delay Mix is on max to highlight the issue.
The noise itself, however, is noticable as soo as you crank the mix
up to 9 o'clock.
Patrick
Noise Delay Cuircuit
- Attachments
- Noisy.mp3.zip
- (137.59 KiB) Downloaded 62 times
Re: Noise Delay Cuircuit
That sounds about right. The analogue delay circuit is a bit noisy. It is most noticeable if you you have the cutoff frequency turned down and the delay mix set high.
John
John
FuzzyCat Software - Software tools for musicians - www.fuzzy-cat.com
"Chonky" - free global parameter manager software for the Moog Matriarch and Grandmother - www.fuzzy-cat.com/products
