I have bought a Tech 21 Midi Mouse for changing the preset sounds on my Minitaur.
However nothing happens when I try changing the sounds via the footswitch. This is an imperative part of my live playing as I use up to 4 sounds in one song.
What (if anything) am I doing wrong?
Changing Minitaur sounds via footswitch
Re: Changing Minitaur sounds via footswitch
So you connect the MIDI Tech 21 Midi Mouse into the MIDI Input of the Minitaur. And use USB for a keyboard? Or how is you setup connected. And are the MIDI channels are set right?
Sequence:
Sequence:
The Minitaur uses Program Changes (PC) to switch through presets. I do this with my Roland Spd-Sx. Make sure PC's are enabled in your midi mouse, if that's an option.
