Little Phatty Firmware Update 3.2 Issues
Hey all,
Just picked up a Little Phatty and have been enjoying it immensely. It's the stage 1 version without USB. It currently has firmware 3.1 on it. I went to go and update the firmware with the supplied HEX file for 3.2(StageSystem_v3_21_Update.zip). I followed the instructions to load the file into the Phatty Loader, held down Master to get the synth into boot loader mode and then send the HEX. It sends everything over but I get a checksum error every time. I've tried pretty much every combination of packet size and speed with no luck. I can load the 3.1 firmware with the Sysex file just fine, and that's what I've reverted back to.
Has anyone had this issue? Is there a Sysex file I can try for 3.2 instead of the HEX? Thanks for any help you can provide!
Re: Little Phatty Firmware Update 3.2 Issues
try to change buffer/timeout settings in SYSEX loader software
maybe you also will need a different USB cable/port or direct DIN MIDI connection via separate interface
Best regards, Ruslan Tagirov.
Toyz: MBPro+Live 9.x+LogicProX, Moog: LP StageII/Sub37/Grandmother/MF-104m/MG-105m, Nord: Stage2 SW73/ModularG2Engine, Roland: MC909/TR-8, Korg: MS-20, R-3, OTO: Bisquit/BIM, etc.
I'm experiencing the exact same issue as OP. I have a LP stage I with CV out mod. I was about to go purchase a new midi device thinking mine was corrupting the sysex, but lo and behold firmware 3.1 680 loads perfectly fine every time. Anyone else have any ideas?
I was just about to update my stage 1. I would prefer sysex over hex if possible. I need to make sure I have an old OS on hand, then I'll give it a go and report back.
I am having the same problem! I have a Little Phatty Stage 1.
It will receive the 3.1 firmware just fine using the loader. When I try to update to the newer 3.2 firmware, I get a checksum failure every single time. I've tried adjusting the speed to make it slower (as recommended) but still no success. I also tried different Midi Interfaces and computers, still no success.
So I load 3.1 again and it works no problems (at original speeds too)
Can anyone shed some light? 3.2 just doesn't want to work for some reason... has anyone else struggled with this?
Thanks much!
Thanks much!
icosa wrote:Hey all,
I AM HAVING THE SAME PROBLEM!
Not really an issue, but a question: I have usb on my LP stage II (running os version 3.1) - can I update to OS 3.2 using the midi din connector or do I have to use the usb connection?
Thanks,
Mark
Thanks,
Mark
Hey all. I contacted Moog support about this issue and although they were really helpful I could not get the 3.2 firmware to work. Again, I am able to update to every other version I've tried previous to 3.2. As far as I can tell the 3.2 file on the site currently does not work with the Stage 1 Little Phatty. Hopefully they will update it to fix the checksum error.
Any word on a fix for this yet?
I am also having this issue with a stage 1. I contacted support but sadly they have not followed up with me. Hopefully this is resolved soon!
I had this issue when updating my LP Stage 2
Having followed the instructions in the text file included with the updater I kept ending up with the message -Please Send Firmware
I resolved the problem by experimenting with the timing settings in the Phattyloader app, basically it worked when I set the timing interval to "500ms slow" packet size "256 bytes" normal (updating using a USB connection from my macbook pro)
Be aware though that presets 1-56 disappeared during the update
addendum to last post
on 2nd reboot all my presets came back
I've tried all sorts of combinations with intervals and packet size. No Luck. I can also get the beta 3.2.685 loaded with no issues. Seems to me like the issue is directly related to 3.21
Calling on Amos,
Any word on a fix?
Any word on a fix?
I am having the same issue with my Phatty Stage 1 also.
