Little Phatty - Getting the sound I want, attack time
Posted: Tue Sep 14, 2010 1:49 pm
by addictedtofunk
Hi
Im trying to get my little phatty to have a punchier sound - regardless of how hard I hit the keys....at the moment if i press the keys hard i get a punchy sound but if i press them softly i get a less punchy "softer, rounder" sound, how do i make it so that regardless of how hard i press i get the same sound(or change the range between hard and soft) so that more often I get a punchy sound
So what im asking is how to change the input sensitivity of keys pressed
Re: Little Phatty - Getting the sound I want, attack time
Posted: Tue Sep 14, 2010 1:54 pm
by tagirov
for my LP stage II
press Master
dial Value to Advanced Preset menu
then press Cursor to select second line of menu
then dial Value to Filt Sens option
press Cursor and dial Value to change Filter Sens value from -8 to 8
and then store the preset as usual (if you need)
hope your LP has the same menu
Posted: Tue Sep 14, 2010 2:59 pm
by Sir Nose
A value of 0 produces no change to the filter cutoff no matter how hard or soft you play
Posted: Tue Sep 14, 2010 10:31 pm
by addictedtofunk
ok great thanks!
now the little problem i have is when i press a key and holding it down and pressing another key i don't get the attack of the second note
how do i get it so every note i press(even if i have others already depressed) has the punchy attack?
Posted: Tue Sep 14, 2010 10:37 pm
by addictedtofunk
found it.....
advanced preset menu...changed gate to leg off
thanks
Posted: Thu Sep 16, 2010 2:50 am
by tript
Legato setting has nothing to do with how hard you hit the keys...
...buuuut I am glad you got what you needed.
