prodigy tuning
Posted: Fri Dec 03, 2004 2:13 pm
by atkbg
Hi. I just got my first moog. A prodigy. Everything works well, but...
Once I tune the second oscilator to the first, then sync them, it drops roughtly 1/4 step. Is this normal?
Posted: Fri Dec 03, 2004 3:18 pm
by sundaeclubber
Congratulations!... The best value moog ever!
Quite normal to shift in pitch a bit.... Is it unbearable?
Prodigy Pitch Shift
Posted: Fri Dec 03, 2004 3:37 pm
by atkbg
It's bearable as long as I remember to adjust when locking or unlocking the oscilators.
Can this be fixed or is it inherent?
Posted: Fri Dec 03, 2004 4:07 pm
by sundaeclubber
Just how much does the pitch change?
You should note that the sync function disables the pitch bend function of the bend wheel, and changes it to a phase adjuster.... Is your pitch bend wheel in its center-detent position when you operate the sync switch?
Posted: Fri Dec 03, 2004 4:23 pm
by atkbg
Hummm.....
I'll have to check on that. I'm pretty sure, because is seems to be about a 1/4 step up every time.
Also, since I'm just getting use to the pitch bend feature (I dont pitch bend a hammond that often, so its a little strange) I generally leave it alone, (in the middle) but I like the phase shift when the oscilators are locked.
Posted: Fri Dec 03, 2004 4:32 pm
by sundaeclubber
Doesn't sound like a serious fault, but could do with checking out I think.......
What Hammond do you have?
Posted: Fri Dec 03, 2004 4:48 pm
by atkbg
a 1938 AB
a 1948 CV
a 1957 M-3
a 1963 M-3
a 1968 M-100
a 1971 B-3
Quite a little music room, huh?
Posted: Fri Dec 03, 2004 7:12 pm
by sundaeclubber
Lovely!!
I have an A102.... The one that looks like Celine Dion and sounds like Aretha Franklin......
Check out the photos on
http://www.technostalgia.org
No Hammond, but a few other goodies!
Posted: Mon Dec 06, 2004 10:20 am
by atkbg
Nice photos.
There's a couple of my dreams in them: (clavinet and a CP-70)
Also, what are your thought on putting an input on the prodigy? I've heard later models had one.
Posted: Mon Dec 06, 2004 3:40 pm
by sundaeclubber
That's a CP*80*!!!
The later Prod had jack sockets for trig, cv-in and audio in for processing thru the Moog filter I think.... Not totally sure because mine's an early one, but that's what I remember of the one I borrowed sometime in the 80s.
The cv and trig inputs mean that it's reasonably easy to rig up an external control from say, a MIDI out using a Philip Rees or Kenton box of tricks, but the Moog filter processing of external sources is far better when it's done with a Moogerfooger I reckon. I don't think it's worth drilling holes in the back of a tidy Prodigy for.
HRx
Posted: Mon Dec 06, 2004 3:49 pm
by MC
Is that one of the new Mellotrons?
Posted: Mon Dec 06, 2004 3:51 pm
by sundaeclubber
MC wrote:Is that one of the new Mellotrons?
No fear!!
That's a genuine Streetly!
Posted: Mon Dec 13, 2004 5:23 am
by propylon
here a possibility for the tuning-problem:
please center the pitch-bend-wheel. Then measure with digital voltmeter the voltage between GND and the wiper from pitch-bend-potentiometer. This should be ideally 0V. But i think in reallity you will measure some hundred millivolts. Add a resistor (perhaps in the range of 100 kOhm, you have to try) from the wiper of pitch-bend-potentiometer to +12V or -12V depending to your voltage measured before.
Please excuse my bad english.
Best regards.
Posted: Tue Dec 14, 2004 1:59 pm
by Nick Montoya
Hey bro...
The reply before mine sounds like a good possibility but only if you're an experienced tech. I own an early Prodigy as well (#2329) without CV/Audio In jacks etc..... I notice the same with mine and have chosen to be lazy and not do anything to fix it.... Do you have the Service manual? I believe I have two differnt versions of it. One is a very Technical one from Norlin and has all of the test procedures (if of course you have the right equipment i.e. digi voltmeter , etc) and the know how. For me its not a huge problemo.. I love the osc sync function and usually leave it there, especially for live performance.
I own four other synths too (including one of the three model D's that Kevin Lightner has graced his beautiful hand-cut blue back lit wheels to) .
http://www.synthfool.com/nicksmini.jpg I usually get my shows started with a nice minimoog bass line, get some way dubby Ms2000 in there and then hit em with the osc sync super loud and clear on the Prodigy ! The prodigy and mini together, live- through a great Analog system can get all the ladies movin' their butts
The solo out some hi hat action and get r2d2 going on the Realistic/Moog MG1... Random shape mod is the shizznit...
Prodigy schematics
Posted: Tue Feb 08, 2005 5:16 pm
by atkbg
Does any one have a ledgable scan of the Prodigy schematics?
I found one on the web, but I cant read the R values for the Modulation Rate circuts.
My modulation rate is basically useless now. It does not make any noticable difference until almost completely turned. Then, there is only a minute range from nothing to fully modulated.
