Oscillator/Wheel calibration.
Posted: Sun Sep 26, 2004 3:51 am
by Joog
I was wondering how to calibrate the oscillators and pitch/mod wheels without sending the keyboard back to the factory. There must be a way to fix it oneself or with a technician, because I don't live in the states and it'd be great to fix it without having to pay the high international shipping rate. If there is any documentation or if someone would help me out, that'd be a major plus.
Posted: Sun Sep 26, 2004 9:33 am
by taschenmusikant
you need to adjust the pitch bend amount only, if you hear pitch changes when changing the pitch bend value in the menue.
The procedure of adjusting the pitch bend is descripted in the software 2.1 manual pdf-file. You need only a #-screwdriver to open the Left Hand Control unit.
I´m from germany and I can give you more advice if necessary.
You find the manual on this side in the download section (Signature Voyager/ Software).
Posted: Sun Sep 26, 2004 1:21 pm
by Joog
Thanks, my voyager isn't that advanced as far as OS is concerned, so I can't adjst the pitch bend in menus. I'm still running 1.0 because it won't respond to sysex, and am probably going to send the Moog back to factory for them to do something about it, but I'd like to learn how to tune the oscillators and calibrate the wheels for my own personal reference. My pitch wheel seems to go a little bit higher than it should, and it seems that my mod wheel's lowest position still triggers the modulation a touch.
