LFO clock divider problem
Posted: Mon Jan 04, 2010 5:23 am
by cla
user manual says that when LFO sync mode is set to "clock" you can adjust the clock divider with the modulation knob, but this doesn't happen on my phatty. any idea?
little phatty stage II
os 2.1
Posted: Mon Jan 04, 2010 6:55 am
by MarkM
Works on my Tribute, but you have to be on the clock divide menu while in the arp menu to do so. Make sure the cursor is on the divide numbers. However, you still have to use the value knob and not the Mod pot.
Posted: Mon Jan 04, 2010 7:26 am
by Maskin
According to the manual it should also work with the modulation knob, I just tried it myself on a Stage 1 and it didn't work.
A bug maybe?
Posted: Mon Jan 04, 2010 8:07 am
by cla
I think it's a bug too, Maskin. I also tried to send MIDI CC03 and the LEDs are moving, but I still can't ear the clock divider step, just like moving the knob. then I tried to set a POT MAP but there is no a clock divide option in the routing menu.
Posted: Tue Jan 19, 2010 12:51 am
by donmacp
Technically it should work according to the manual's instruction, but it seems to be a common experience. There must be a glitch somewhere.
