FreqBox esoteric dharma
Posted: Mon Dec 07, 2009 8:50 am
Hi everyone,
I've been lurking on this list for a while now, but someone outed me on the Theremin forum, so I decided to come clean here as well.
I play shakuhachi (my main instrument) and theremin, with several MFs as well as other toys. Amongst the MFs is a 107, and it surprises me that in all the discussion of this bix no-one has mentioned what seems to me to be one of its more esoteric but most sonically beautiful uses.
Far from being a complex or glorified distortion box, the 107 can be viewed as an analogue implementation of 2-operator FM, as pioneered digitally by John Chowning and implemented with varying degrees of complexity in the Yamaha DX synthesizers, culminating in the FS1R synthesizer. (FM of course appears in lots of software, and is easy to build-your-own in MAX/MSP for instance).
What we basically have is a VCO with cv in for frequency control, with variable waveshape, and the ability to offset its frequency. The important thing, though, is the ability to use an audio signal to modulate the frequency of the VCO, as well as enveloping the output signal via an envelope follower, to make the output follow the input signal level.
What htis means is that if you provide a monophonic input audio signal and simultaneously a cv that tracks that signal's pitch, you can modulate the VCo with a constant interval between input and VCO. If the audio signal modulates the frequency of the VCO, the result is analogue 2-operator FM synthesis, and the exact sound produced is determined by the FM level, and the complexity of the waveshapes of the input and the VCO. With complex waves, the harmonics go wild, giving the impression of highly.coloured distortion. If you keep the waveshapes simple - triangle, sine - you have a chance of producing delicate timbres, which run the spectrum of FM metallic etc, depending on what interval is set between input and VCO. The tracking of the VCO is not perfect, but still pretty usable, in my experience.
Now to do this, you need something that can produce a simple audio signal and a cv that tracks its pitch. A VCO module driven by a keyboard can do this (think Voyager with breakouts for signals and cvs). But Moog (meaning Bob and everyone else who's been involved) came up with a perfect way of doing this for expressive playing. Firstly the Etherwave Pro theremin, which can put out a pretty pure signal, and a cv. Audio signal to audio in of 107, pitch cv to VCO cv in. Voila - a theremin that produces FM metallic sounds, with accurate tracking, all analogue. (A few years ago, the lore was that this was impossible in analogue...) Secondly and more recently, the Etherwave Plus. While I don't own an EW+, I assume that the same setup works with it as well. Even with the purest waveforms, the output signal can get pretty rich in harmonics, so I find it useful to put it through an MF101 - which of course can be controlled by the volume cv out of the theremin. This becomes an extremely expressive instrument with a huge range of timbres.
So, if you own a 107 and haven't tried it in this way - you might want to experiment...
Jim F
Jim F
