Little Phatty USB type?
Posted: Sun Oct 11, 2009 2:46 pm
by grantb5
Kind of a dumb (pre-purchase) questions here. Does the LP enumerate over USB as a MIDI device or some other kind of device? If it identifies as a MIDI device, can you then use the 5 pin DINs as MIDI I/O for the PC?
Also , can you do firmware updates (using SysEx or other) or USB or 5 pin DIN (MIDI)?
Re: Little Phatty USB type?
Posted: Sun Oct 11, 2009 3:19 pm
by CTRLSHFT
grantb5 wrote:Hi,
It shows up as a USB Composite device. Firmware updates should be done with MIDI I/O for best reliability imo. I haven't tried FW updates with USB though, maybe Amos could shine some light on this?
Posted: Sun Oct 11, 2009 4:00 pm
by grantb5
Thanks for the info. BTW I'm a Windows user. Does Moog supply drivers of their own or is it some standard device type?
Posted: Mon Oct 12, 2009 7:15 am
by nickster
Standard windows drivers, usb os updates work fine using the Sound Tower editor software. Should also work using SysEx in a sequencer via usb.
Posted: Mon Oct 12, 2009 9:02 am
by grantb5
Cool. And when connected by USB, what of the 5 pin DIN MIDI connectors -- can you then use the 5 pin DINs as MIDI I/O for the PC? That is, does the LP act like a MIDI interface allowing other devices connected to the LP to connect to the PC (if you get my drift)?
Posted: Wed Oct 14, 2009 2:43 pm
by T7
grantb5 wrote:Cool. And when connected by USB, what of the 5 pin DIN MIDI connectors -- can you then use the 5 pin DINs as MIDI I/O for the PC? That is, does the LP act like a MIDI interface allowing other devices connected to the LP to connect to the PC (if you get my drift)?
Haven't tried it, but yes.
