moogerfooger controllers ...
Posted: Tue Sep 01, 2009 11:27 am
by The Radium King
hi there. i'm new here, and new to modular sythesis. i have a cp-251, a lowpass filter and a ring mod, and am scratching the coin together to get a delay as well. i am a guitarist, and have many other effects pedals, including an electroharmonix hog. i would note that the hog takes cv control of the expression pedal, which is what initially got me buying moogerfoogers in the first place.
i am currently looking for a method to get cv control that allows me to plan longer phrases. that is, some kind of sequencer with cv output. i would also like the opportunity to use this device to get some rudimentary vco action from my ring mod and, in the future, a freq box or modular synth. finally, if things go that route, it would be nice to have a cv controller of some sort - a cv keyboard or somesuch.
i am aware of several pure analog sequencers that consist of timing chips and pots to tune voltages, but i am wondering if i would be better served with a digital sequencer and a midi/cv converter. this would allow me to sync/control my microkorg, as well as avoid constant tuning, etc.
so ... any suggestions for analog cv sequencers ... or ... digital sequencers ... and ... good midi/cv converters ... and/or .... cv controllers?
thanks for any and all help.
Re: moogerfooger controllers ...
Posted: Tue Sep 01, 2009 3:41 pm
by CTRLSHFT
The Radium King wrote:hi there. i'm new here, and new to modular sythesis. i have a cp-251, a lowpass filter and a ring mod, and am scratching the coin together to get a delay as well. i am a guitarist, and have many other effects pedals, including an electroharmonix hog. i would note that the hog takes cv control of the expression pedal, which is what initially got me buying moogerfoogers in the first place.
check out the
Future-Retro Orb!
Posted: Tue Sep 01, 2009 3:46 pm
by toryjames
1) I have a Paia MCV8 that I am happy with, it has 8 cv outs and is very inexpensive. But it is a kit so you have to solder the thing together and calibrate it.
2) If you want something ready to go out of the box I also have a Kenton Pro-Solo Midi-CV converter that is pretty easy to work with and not much more $ than the Paia. Though it only has 2 CV outputs and a gate output.
3) If you don't mind using a computer and want greater versatility and accuracy you might want to check out the MOTU (Mark of the Unicorn) Volta software. It works with MOTU's audio interfaces utilizing the audio outputs as CV signal outs. It has a calibrate function that tunes the CV signal to whatever oscillator you are using (without having to open up the oscillator and tune it yourself), if you want to use the Ring Modulator's oscillator this would probably be your best bet. From what I hear it is difficult to use as a tuned oscillator because it is not internally calibrated to 1 volt per octave.
Hope this helps.
Posted: Tue Sep 01, 2009 4:27 pm
by The Radium King
thanks folks. i'm currently looking at the orb and the mfb step64. the orb is cool in that it incorporates a midi/cv converter so that i can use a cheap midi keyboard to produce cv. the orb is only single track, however ...
the mfb step64 is multi-track, so i can get all kinds of crazyness going on, but it doesn't appear to work as a midi/cv converter (that i can tell from the manual, anyway). if anyone with any experience with this could comment ...
the other sequencer i'm considering is the synthesizerdotcom unit. cool, but again a midi/cv converter would be required. the paia unit looks the ticket, but then i'm in the modular downward spiral, selling blood for more vco's and adsr envelope generators ...
or, get one of the many midi units out there and the kenton midi/cv converter ...
for some luddite reason i am resisting the ease of going to a soft sequencer. i'm not sure why, other than it may also be the guitarist in me that doesn't trust anything he can't spill beer on.
Posted: Tue Sep 01, 2009 5:37 pm
by analoghaze
I have a Dot com Q119 sequencer that I really enjoy.
It changed they way I make music.
Very fun. I would highly recommend it to anyone with Moggers.
Posted: Tue Sep 01, 2009 8:47 pm
by toryjames
You know what? Just wait for the Moogerfooger Sequencer to come out.
Posted: Tue Sep 01, 2009 11:16 pm
by slabwax
toryjames wrote:You know what? Just wait for the Moogerfooger Sequencer to come out.
I hope that's not when hell freezes over.
Posted: Tue Sep 01, 2009 11:30 pm
by CTRLSHFT
slabwax wrote:toryjames wrote:You know what? Just wait for the Moogerfooger Sequencer to come out.
The day they complete the moogerfooger line w/ an eg and vca module is the day i expect to see a moog seq in development.
Posted: Wed Sep 02, 2009 11:05 am
by The Radium King
that would be a good day. dunno if i want to wait, however (general consensus is that hell is going to get hotter before it ever freezes over ...).
the electro-harmonix hog is currently serving as my vca and eg. while digital, if feels and sounds analog. i think they decided to go digital given the huge amount of note tracking that has to happen (i've heard the pigtronix analog guitar synth and it is very glitchy).
the hog is a multi-octave unit with octave down, two octaves down, octave up, octave+fifth up, two octaves up, etc. etc. etc. it has a lowpass filter with resonance control and attack/decay control (two controls - one for the upper octaves and one for the lower). it has a spectral filter and seven expression controls that meet hte moog cv standard - filter sweep (with resonance) wah, volume, step bend, octave bend and two different gliss/latch options.
works great for guitar.
ps, i'[m leaning towads a cheap midi/cv converter. that provides the most options and doesn't preclude an analog sequencer in the future.
of course, if someone makes a nice multi-track sequencer with built-in midi/cv conversion for a good $$ i'm all in ...
Posted: Wed Sep 02, 2009 3:08 pm
by r05c03
The Orb Sequencer from Future Retro?
Posted: Wed Sep 02, 2009 5:31 pm
by DontBelievetheHype
The Radium King wrote:that would be a good day. dunno if i want to wait, however (general consensus is that hell is going to get hotter before it ever freezes over ...).
I have an enjoy a HOG, but sonically it is the very definition of
digital with its chimey tone (though the lowpass and spectral gate can reign it in). Also, other than having 'guitar synth' written on it, it has a quite a different feature set than the Mothership, and it isn't really fair to compare the two. I haven't heard too many good things about the Mothership either, but it is more of an analog "synth" while the HOG is a basically a digital harmonizer that can track anything, even the lowest notes on bass (well, not complex chords, but everything else including dirty/shaped signals). Great pedal though and all the EHX stuff is scaled well for use with the MP201/EP2/etc. The Glissando mode is too much fun..
I don't have any comments on the sequencer, other than that I've been very interested in the MOTU setup..
