I'm not an expert on the MP-201, but it should work like most other midi interfaces. Connect the MP-201 to computer via USB. Connect whichever output you want(cv or midi) on the MP-201 to whichever input you want(cv or midi) on the LPTE.MichaelPeterTrowbridge wrote:Yes! Especially I would like to know whether I will be able to send the sequence to my (hopefully arriving on saturday) MP-201 via USB and then from there via MIDI or CV to the LPTE?patobrujo wrote:... but i feel the explanations may be useful for someone else here...
The cv inputs on the LPTE should already be configured for the most part. The midi input needs to be assigned. Make sure it is set to whichever channel you willl use(prob. CH.1) and you set the midi clock as external if you want the sequencer to determine the time. This is all explained in the LPTE manual, if you have not read the midi section, I would suggest doing this now.
Once you are connected and configured on the hardware end you must configure the software. In all VST software there are options which allow you to select multiple midi functions. The LPTE should appear on whichever software you are using as a midi device. Make sure it is selected on CH.1. For this example make the midi channel output to CH.1, same as input on LPTE. I'm not sure if this is too simple of an explaination, or too complex for you guys. It's really easy once you understand "midi flow", but I hope this helps at least to start!
P.S. READ THE MANUAL!!!
