problem headphones output
Posted: Thu May 07, 2009 12:16 pm
by sechu
I have bought a voyager rme of the second hand and the exit of earphones does not work well in stereo, only a channel.
Do you know that problem is?
Posted: Sun May 10, 2009 12:58 pm
by till
There are many different things that might cause this. Ranging from a broken connection of the socket to some defect OP-Amp chips on the analog board.
Better ask a synth experienced technician for details. This is not something that happens so often that one can new the answer without having your unit on his desk.
Posted: Sun May 10, 2009 7:04 pm
by acorkos
try a different pair of headphones, just to rule out that they're not the problem
Re: problem headphones output
Posted: Thu Sep 26, 2019 5:46 am
by Miawnus
Did you find a solution?! I have a Moog Voyager with stereo problems.. I cannot hear anything on the R channel.. both headphones and main output is dead...
Posted: Wed Oct 02, 2019 5:01 pm
by RL
Hi Miawnus,
is there a change when you select different filter poles?
It could be a filter issue...
