MP-201 no Gate Signal
Posted: Fri Nov 28, 2008 9:23 pm
by dkdent292
hi folks,
i´ve tried to use the MP201 to trigger my Roland System 700 via GATE and it didn´t work :(
the LFO Square Wave could, but when i choose the gate mode nothing happens, even no lights are blinking in this mode.
is this a bug or a feature? ;-)
any ideas?
dirk :-)
Posted: Sat Nov 29, 2008 3:41 am
by Bryan T
It sends the gate signal when you press a button (I think it is button 4 in Single Channel Mode). Is yours not doing that?
Bryan
ep 201
Posted: Wed Dec 03, 2008 6:55 am
by dkdent292
yes, i know. after a os update the trigger button works!
btw. is it possible to trigger the gate via MIDI?
for a steady beat it would be nice to use a midi sequence.
the midi triggered LFO did not work correct. sometimes the timing is a bit off :-/
dirk
Re: ep 201
Posted: Wed Dec 03, 2008 9:11 am
by GregAE
dkdent292 wrote: is it possible to trigger the gate via MIDI?
dirk
Hi Dirk,
To trigger a gate via MIDI, you simply need to send the correct MIDI Continuous Controller value to the Multi-Pedal:
0 - 63 = Gate OFF
64 - 127 = Gate ON
Hope this helps!
- G
mp201 gate
Posted: Thu Dec 04, 2008 9:26 am
by dkdent292
yeah, controller 80 works fine! excellent.
now i´ve a very good live trigger and only need a 10volt amplifier to amp the 5 volt signal for my system700. momentarily i use the env follower to trigger.
thank you very much!
dirk :-)
