External Audio Level CV Control?
Posted: Mon Sep 29, 2008 9:29 pm
Hi there,
How come I can't patch either of the Mod buses to Ext. Audio Level? Why you may ask?
Well, I have the VX351/CP251 with my voyager and have upgraded to OS 3.4, and I would like to use the filter envelop to control the level of effects. For example, I could run the voyager's right single back into a distortion pedal, and then into the external audio, and have the distortion slowly envelope into the note. You can do this with Mooger Foogers with a CV controlled mix level, but not other pedals.
You could also use this with other sounds, so if you had a second sound source, synced up, you could have a second note added in to the mix via the envelope, or have it tremolo wihle the voyager sound is constant.
As you can already do this to the other mixer levels, could this be an easy fix in 3.5? anybody got any patch ideas how to make this work in the meantime?
Todd
Todd
