Typo on Voyager front panel.
Posted: Wed Apr 02, 2008 7:25 am
Well to start with the positive: I now fully understand how MOD1 and MOD2 works with the mod bus. The slightly funny/scary thing is the reason that I have been mystified by MOD1 and MOD2 is *tada*: Mistake on the Voyager frontpanel labeling.
Ok: In the manual in the VX-351 section (page 65) you find that "The MOD2 Input is a CV input on the Voyager that is an external modulation source for the Mod Busses." Note the plural in the last word "Busses". When I read this the first time I thought that it was a typo in the manual because the frontpanel states that ext. modulation on the MOD.WHEEL Bus comes from MOD1 and ext. modulation on the PEDAL/ON bus comes from MOD2. But no, the manual has got it exactly right. The frontpanel is wrong, and I am sorry, but this is no april fool.
Here is my claim: On the frontpanel, MOD.WHEEL, SOURCE: Here you can select the source labeled ON/MOD1. This should have been labeled ON/MOD2.
In fact in reality there is no connection whatever to be made between MOD1 and the MOD.WHEEL Bus!
How to test my claim:
This is easiest if you have an external LFO or other kind of voltage source.
I will you an LFO in my example:
Chose a plain sound so it is easy to hear what is going on.
Plug the ext. LFO into the MOD1 input.
Set the MOD.WHEEL Source to ON/MOD1.
Set the MOD.WHEEL Destination to Pitch.
Set the MOD.WHEEL Shaping to ON/PGM
Turn up the MOD.WHEEL Amount knob.
Now play as you turn up the mod wheel. What we should be hearing is our ext. LFO modulating pitch as we open the modulation wheel. But what we DO hear is the pitch being controlled by the mod wheel. No modulation from our ext. LFO is heard.
Now plug the ext. LFO into the MOD2 input and voila: The patch now works. When we raise the mod wheel, the ext. LFO modulates the pitch.
This should clearly demonstrate that MOD2 is in fact the external modulation source for the MOD.WHEEL BUS as well as for the PEDAL/ON Bus.
What does MOD1 then do? Well, again the manual is spot on: "The MOD1 Input is a CV input on the Voyager that determines how much of the PEDAL/ON Mod Bus Source goes to hte PEDAL/ON Mod Bus Destination."
Actually you can regard MOD1 a shaper of the PEDAL/ON shaping.
And note that MOD1 does not do anything to the MOD.WHEEL bus at all (unless you go into EDIT: PGM Shaping 1 SRC, and select MOD1 as shaping source.)
So dear Moog guys: Feel free to send me new gear for beta testing, haha.
(And should anybody prove me wrong, I will of course eat 5 patch cables and a pair of headphones.)
