I just received the MF Rackmount kit from Moog, and I just need one clarification: are you supposed to leave the bottom plates off of all three MF pedals when you use the rackmount kit? Or do you just leave the bottom plate off of the middle MF pedal (the one with the sides removed)?
Thanks,
Rack Mounting of MF Pedals
MF 102,White MF 103, MF 105B, Minitaur, and an LP Stage II w/ CV Out Mod as well!
I have all bottom plates attached, I guess it doesn't really matter that much..
[size=75]"I like to play with electronic noise makers. I hope someone wants to listen, and if not, I'll still be up at 3 am making sequences in the dark, drinking coffee, and burning expensive incense." [i]Rod Modell[/i][/size]
