Page 1 of 2
Suggestions for using S&H?
Posted: Mon Nov 12, 2007 1:59 pm
by crs.one
I have a voyager, vx351 and cp 251.
I have had trouble understanding the concept of the sample and hold circuit. :oops: Can anybody give me an example of a few settings to try so I can hear what's going on, or ways to make the circuit useful?
Chris
Posted: Mon Nov 12, 2007 3:04 pm
by synthetic
The most common use is noise as the input, resulting in a random stepped wave as the output. The manual does a good job of explaining this application.
Posted: Mon Nov 12, 2007 4:10 pm
by latigid on
Alternatively, patch a triangle wave into the input, and the output will be a "staircase" waveform (i.e. a stepped triangle wave)
Posted: Mon Nov 12, 2007 5:57 pm
by analoghaze
Use the S+H output on the CP-251 to the filter or wave in on the Voyager with a simple initilized patch.
Experiment and listen to the results.
Re: Suggestions for using S&H?
Posted: Tue Nov 13, 2007 6:24 am
by Modularfan
crs.one wrote:I have had trouble understanding the concept of the sample and hold circuit. :oops: Can anybody give me an example of a few settings to try so I can hear what's going on, or ways to make the circuit useful?
Chris
There are some audio examples of S&H on MoogSpace that illustrate the concepts explained in the manual:
https://www.moogmusic.com/members/?sect ... ile_id=383
Posted: Wed Nov 14, 2007 2:42 pm
by earsmack
Subtle is key here for me...apply a s&h voltage ever so slightly to the pitch of an osc or the filter frequency or resonance, or speed of the lfo for that matter, etc. It can add just a touch of life without resorting to an "obvious" s&h sound.
Posted: Fri Nov 16, 2007 1:45 pm
by LDT
- or sample a squarewave. The result could be a rhythmic "either-this-or-that" randomness. E.g. it could be a random selection of two octaves or two different waveform. Experiment!
Posted: Tue Nov 20, 2007 2:34 am
by sir_dss
So to get a snare sound you would use the "Sample" section with a noise source and a short release?
Posted: Mon Nov 26, 2007 3:13 pm
by Emil
If using the CP-251 there might me a better spread of notes if using the attenuators. Then the 351 has attenuating there too.
Posted: Thu Nov 29, 2007 10:05 am
by Nick2012
crs.one,
I don't know if your question has been answered to your satisfaction, as you have not responded (publicly). So I'll go ahead and add my 2 cents. The output of the S&H is a random stair step pattern. In terms of voltage, an example output string might be, +1.0, +2.4, -3.7, -0.5, +4, +5, +1.1, -3.0.... etc. The only thing not random is the rhythm of the output. How long the voltage is held at the output of the S&H is dependent on the LFO speed. (I'll mention here that you can also make the rhythm random by modulating the LFO speed with the S&H). The S&H circuit generates an output CV by taking periodic snapshots of a white noise wave. A white noise waveform is like the other waveforms (square, sawtooth, triangle, etc.). The wave rises and falls above and below a 0 volt center line. But, unlike those other waves, it is NOT periodic. At any given moment, how high it rises or falls, and the slope of the rise or fall, is random. And any given up/down cycle may or may not cross the 0 volt center line. Thus, at regular intervals, if you take snapshots (samples) of where the wave is, and temporarily hold those voltages in a single buffer, the output of the buffer will be a random stair step. There's an internal squarewave (under the control of the LFO) which triggers the S&H circuit to take a sample. That's why the manual says the S&H has 2 inputs (white noise and a square wave). Think of the S&H circuit as a camera. The white noise is the landscape and the squarewave operates the shutter button. Of course in this case, the landscape is a chaotic, ever-changing, collage of light and dark (like what you see on a TV screen when there is no incoming signal). You can send the output of the S&H to a destination to modulate a certain parameter (filter cutoff, vco pitch, etc.).
Posted: Fri Dec 14, 2007 12:33 pm
by EricK
Heres something that I found on this website.. Its also a great resource for informatoin about modular synthesis
http://arts.ucsc.edu/ems/music/equipmen ... synth.html
SAMPLE AND HOLD
The sample and hold module was originally developed to be a cheap alternative to a sequencer (all those knobs are expensive). Its basic function is to capture a momentary voltage and keep that voltage at its output until told to sample again. (Keyboards contain this circuit as a matter of course.) If you sample a steady waveform at a slow rate (aliasing) a variety of repeating patterns will emerge that depend on the precise relationship of the two frequencies involved. If you sample noise, you get a totally random output.
Sample and hold with noise input
Most sample and hold devices have a dedicated low frequency pulse oscillator (called a clock) to provide steady triggers.
[Digital systems that claim to have a "Sample and Hold" effect (usually an option for the LFO really produce random steps at a steady rate.]
5.34 THE SAMPLE AND HOLD AT WORK AND AT PLAY
Look back at section 5.2 for a diagram of what a sample and hold does. The output is a step-like control voltage that depends on the nature of the input and the relationship of the input frequency (if any) to the clock rate. Here are the general rules:
If the input is noise, the output is random.
If the input is a waveform with a rate slower than half the clock rate, the output will resemble the input (in steps of course).
If the input is a waveform with a frequency faster than the clock rate, the output will go in patterns that suggest the shape of the input waveform, but may be backwards or scrambled. (It is possible to get an unchanging output this way.)
To find uses for the S&H, we might consider the most common shapes for controls and their uses. Controls may be stepwise and discrete, like the output of the keyboard (portamento off), or sloping, like the output of an ADSR. We usually use discrete voltages for pitches and "preset" kinds of timbre change. Sloping values are good for envelopes and unpitched (or at least untuned) events.
One thing the S&H does is turn a sloping change into a discrete one, so generation of pitches comes quickly to mind.
The easiest thing to do is indeed to generate a set of funny pitches, using the internal clock to provide a steady rhythm. We also want to syncronize the S&H sample with an ADSR to get clean notes. This is done with the clock trigger out. (Synton users can do this by connecting the ext INPUT to the comparator input. The comparator output is a useful trigger.)
There is a small problem with some S&H designs: they let a little bit of the input signal leak through while they are sampling. This causes a glitch as the voltage changes, but the glitch is kept inaudibly short by making the pulse width of the clock very narrow. If you should want to use an external trigger to get a more interesting rhythm (and you should), you must make the pulse you are using very narrow. If the LFO you want to use does not have variable pulse width, make it using the triangle output and a comparator. If you still can't get rid of the glitch, invert the trigger on the way to the ADSR and turn the sustain off.
Here are some other interesting things to try with the S&H:
Control a filter, sampling noise and triggering with the keyboard.
Control modulation depth (see sec 5.33) of any kind of modulation.
Control pulse width of an oscillator. Use that pulse to trigger an ADSR and the S&H.
Posted: Fri Dec 14, 2007 7:00 pm
by c7sus
Thanks for the article. Looks like a Freqbox might make an interesting S&H trigger.
Posted: Sat Dec 15, 2007 1:15 am
by crs.one
good call...i hadn't responded...and i should give my appreciation to everyone who responded.
in truth, i have been doing some renovations at home so my voyager is safely tucked away, and i haven't had a chance to try any of them yet. but i certainly will.
Posted: Sat Dec 15, 2007 7:43 am
by latigid on
When you do pull out the Voyager, be sure to delve into the Pedal/Mod Buss Prgm/On source accessed through the menu (Edit, I think). You'll find one selection not available on the front panel, namely Smoothed Sample and Hold.
Have fun!
Posted: Sat Dec 15, 2007 12:54 pm
by EricK
Can't you generate a pseudo-smoothed sample and hold by just bumping up the release time on the envelopes a little?
