Little Phatty + Mellotron Sound
Posted: Wed Oct 03, 2007 6:57 pm
by PdMoog
>> I had update the firmware with the new one (os 1.03c), and now
>> i'm tryng to use my Little Phatty into my live setup...
>> My idea is to use it with an expander (an Emu Vintage Pro)
>> and i have patched it via midi with the audio back into the LP audio-in..
Hi people....
...it works !!!!
now i got the expander (e-mu vintage pro) working thru 2 differents
midi port / midi channel / audio out...
(a lot of work on the Emu to do it...but no midi patch bay added)
and the second is controlled from
the Little Phatty and inject sounds into the LP audio in...
for more the LP control.... change preset on the expander
only on the LP expander channel...
without changing preset on the channel controlled from the other
keyboard i use...where i had still all of my old presets ready to use...
so now i have on my LP... presets with the only Moog sound
(linkig a "no sound on the expander")
when other link to active presets and inject sound controlled
from the LP keyboards and whells ....
i'd done a preset with String Mellotron poly Chord (coming from the expander)
and the LP vco setted as keyboard low priority making the bass...
(with a slow glide)
you make the chords (with rigth hand) on the lp
and you have the mellotron filtered on the moog
with low bass added...
...with the left hand you pick low note and you have the
solo moog bass sound ...you release the low note and the moog's vcos
move slowly to the chord's lowest note..
open the whell and you got the S/H on the filter...
at the first touch i'd seen the Brian Eno's smiling face ...displayed
on my PA monitors...
this sound is so good then i'd wrote a new song on the next ten minutes..
Thank You Moog Moog music...for the Little Phatty...
....it is a great instrument !!!!
and it is so fun...and playable...
Bruno
Posted: Sat Oct 06, 2007 3:41 pm
by Amos
Wow Bruno, that sounds like a great setup! Well done.
Send us audio samples if you can... thanks!
-Amos
Posted: Wed Oct 10, 2007 8:15 am
by PdMoog
...sorry Amos,
i cant do it now...i got it setted on my live setup
and i'm working for all configurations and presets i need...
and i have not an easy way to record there....
..and i'm still working for the presets..
(nigth after nigth....)
but the first time it come back home i will find the way to record
some mp3 with a selctions of mine "combine" presets...
Bruno
