Analogue Mode question
Posted: Wed May 16, 2007 9:10 am
i was fiddling with our LP stage last night. this is the first lengthy face time i've had with the LP so i'm still trying to figure it all out.
in the master section there is section called "Analogue Mode". It can be set to snap, track, or pass-thru.
when i had it set to 'track' and selected a preset sound. the OSC-section knob LED would gradually transition from the (knobs) preset position to where the knob was physically pointing. I understand (from what i read in the manual) that this is suppose to happen, but what is the point of this? When I had the setting in "Snap", It would immediately snap to the knobs physical position. The only one that didnt override my preset knob position was "pass-thru".
is this all normal? If someone wanted to use saved sounds (presets), they'd HAVE to go with the "Pass-thru" setting, correct? Track & Snap seem to change the preset, and I dont really want that to happen. Am I using this correctly?
