Why'd you do it ?
Why'd you do it ?
What made you buy the LP instead of the Voyager?
Would you have done so if price wasn't a factor ?
The price is always a factor. Even if you are a millionaire you think twice before you spend 3200,- € (at least those who stay millionaires do). If I was a millionaire I would have thought twice and would have bought a Voyager. I am not a millionaire, so I had thought that I would never be able to afford a Moog synthesizer. Now I have got one and I am very happy with it.
I sold my Moog the Rogue in 1998 for about twice the amount I paid when I bought it new. I spent the next 9 years trying to convince myself that software synths sound equally good, if not better. Deep in my heart I knew that this was not true. I wanted to return to the analog domain, but the price of the Voyager was too high a threshold for me to take that step. The LP was not, and so I got one. Had I known beforehand how it would change my approach to music making, I would have gotten a Voyager right away. However, I will not trade my LP towards the purchase of a Voyager. When my budget allows for it, I will get a Voyager to keep my LP company! And I will not have to think about it twice (now you know why I will never become a millionaire).
RAC is a way to control different parameters of the synth with just one knob without using digital controller data. The voyager does not need such a function because there is a knob for every parameter. So you already have direct real analogue control.robles wrote:RAC: Real Analog Control. I actually don't particularly want a Voyager for that reason. If I'm going for analog, I want analog all the way. I'm very glad I got the Tribute which has RAC for all functions.
The following is a quote from Sound on Sound magazine:doctorno wrote:RAC is a way to control different parameters of the synth with just one knob without using digital controller data. The voyager does not need such a function because there is a knob for every parameter. So you already have direct real analogue control.robles wrote:RAC: Real Analog Control. I actually don't particularly want a Voyager for that reason. If I'm going for analog, I want analog all the way. I'm very glad I got the Tribute which has RAC for all functions.
http://www.soundonsound.com/sos/nov04/a ... update.htm
"Next, I would like to point out another slight deficiency that has become apparent on all Voyagers. The synth's manufacturers claim that the 12-bit A-D converters used to translate the positions of the front-panel knobs into digital values, the interpolation of those values when the CVs are generated, and the scanning speed of the front panel are all sufficient to ensure that the Voyager is indistinguishable from a pure analogue synthesizer. However, this is not the case. To discover this for yourself, just sweep two knobs simultaneously while listening to a patch. If one of the parameters you're adjusting makes obvious changes to the sound — say, the filter cutoff frequency — you will hear audible stepping. To be fair, the amount of 'zippering' is very small, and will bother almost no-one, but it's there nonetheless."
Yes you have analog knobs to change parameters on the Voyager, but they immediately get converted into digital values so that it can save the patch digitally. The digital signal then gets translated back into analog CVs to control the analog sound engine. The Little Phatty is the first synth ever that has direct analog control and digital control at the same time.
The quote from above is why I decided I didn't want a Voyager. I'd rather go for a straight analog synth. But lo and behold, Moog came out with the LP that does have direct analog control, so I went for the TE knowing it was the last design by the good Doctor himself.
I have a SE Voyager and was going to get the LP Stage but found the RME Voyager for not much more than the LP and purchased it instead.
The only thing I thought I'd miss from the LP was the overdrive circuit as an editing option.
RAC will not affect the sound of the LP so how did this beccome the deciding factor for choosing it over the Voyager ?
you are obviously not a live "tweaker" musician....more of a "set & save" studio musician i am guessing?dejon wrote:I have a SE Voyager and was going to get the LP Stage but found the RME Voyager for not much more than the LP and purchased it instead.
There's not possibility of stepping if you have direct analog control. As the Sound on Sound article tested, if you move more than one knob at the same time on the Voyager, you'll get stepping. This can be very audilble if one of your parameters is this Filter Cutoff. You'll hear it change step by step. With the LP you'll only get a smooth sweep. It's subtle, but for a purist, it's a definite consideration for buying a synth.
There are plenty of suberb analog synthesizer manufacturers out there these days. If I'm going for analog, I'm much more concerned that it be all analog than having a product with the Moog name on it. Yes the Voyager can save patches, but the LP does it one better by saving patches, and having direct analog control. But I do confess to having really wanted at least one synth that was a genuine Moog, and the LP was a perfect choice: brand new (I like new), all analog sound and control, and the last design of Bob Moog.
- RL
Hmmm, I thought it's not so easy playing notes and turning on two pots at the same time. Maybe I have to think about it again...As the Sound on Sound article tested, if you move more than one knob at the same time on the Voyager, you'll get stepping
Is it more usual now that modern musicans turning knobs instead playing notes?
If so I have to change the pot routine.
Rudi
Hi Rudi,
A lot of people now let MIDI play all the notes, while they use both hands to change the sound. Can the pot routine be changed to handle this? It's worth a try, I know a lot of people would be very happy...![Very Happy :D](./images/smilies/icon_biggrin.gif)
besides, I can change cutoff and resonance independently at the same time with only one hand... put thumb on Resonance, and first two fingers on cutoff... then you still have one hand to play keys!
