Minimoog Keybed Problem – Sticky and Unresponsive Keys
Posted: Tue Aug 12, 2025 10:38 pm
by bertilsylvander
Lately I’ve been running into an issue with my Minimoog where some keys feel sticky and a few just don’t respond properly. It’s starting to get in the way when I play, and I’m not sure if it’s from dust build-up, humidity, or something else.
Has anyone here dealt with this before? I’d really appreciate any advice on how to fix it without risking more damage.
Re: Minimoog Keybed Problem – Sticky and Unresponsive Keys
Posted: Fri Aug 15, 2025 5:42 am
by till
What Minimoog version? Vintage Minimoog, Minimoog Voyager or one of the Reissue Minimoogs?
Posted: Wed Aug 20, 2025 12:32 am
by bertilsylvander
Thank you, On Vintage Minimoog
Posted: Tue Aug 26, 2025 7:28 am
by till
If the mechanical feeling is wrong, the old bushings need to be swapped for new ones. I did this on my 1979 Minimoog about 20 years ago.
If there are contact problems, use pure technical alcohol to clean the contact springs with a Q-Tip gently (don't brake the springs!) and the two bus boards. If there are stimm contact problems, try to turn the bus bar a tiny bit. So you will get a fresh unused contact surface at least on the bus side.
Posted: Thu Aug 28, 2025 10:33 am
by Elazmo Hiftenfifter
About new bushings: they can run a little wide, which makes them stick to the key channel. You can widen the channel a little, but it might still bind at the bottom of the key travel. I've taken a little off each bushing with a belt sander to make them fit.
The original bushings were coated with a slick surface, then lubed with silicon grease. It helps immensely to coat each side of the new bushings with a thin layer of super glue, let dry, then apply a fast-action silicon grease. I like the Yamaha grease but it's expensive.
