Labyrinth Ableton MIDI help
Posted: Sun Nov 17, 2024 2:41 pm
by sixamoutside
I'm trying to sync Labryinth with Ableton MIDI. Interface is a Clarett 2Pre, and I'm using a 5pin to 3.5 cable.
I've followed manual info for settings and creating an external instrument track for setup. Can't seem to get MIDI to the Labyrinth (no led response).
Any suggestions for my Ableton settings?
Re: Labyrinth Ableton MIDI Hilfe
Posted: Fri Nov 22, 2024 10:39 am
by Funke
I have the same problem, unfortunately I can't find a solution online either: The signal of the LED lamp remains like you. I look forward to your suggestions for a solution, as soon as I have found a way, I will be happy to add it here. Yours sincerely
Re: Labyrinth Ableton MIDI help
Posted: Mon Dec 09, 2024 3:41 pm
by cyril03
I had the same issue until i realised i was using a MIDI 5pin to minijack 3.5 cable, but a type B instead of a type A.
Posted: Wed Jan 08, 2025 10:38 am
by Om Unit
I have the same problem, even with the Type A converter
I've checked the MIDI cable fine and the same cable will sync other devices.
Labyrinth is set to the correct channel too
Anyone?
