Problems with the sub phatty editor
Posted: Wed Jul 17, 2024 3:44 pm
All of a sudden the editor for my sub phatty has stopped working. What happens is that when you click on the vst, a message comes up that says “The Editor cannot connect to the hardware. Please connect your Sub Phatty and set MIDI In and Out on the setup page”.
This worked really well until a few days ago and unfortunately I don't really remember when it worked, but I have definitely used it in May/June.
I run windows 11 on a custom built asus proart550 with amd processor and Live 12 as daw. I usually run the editor via USB.
The editor works just as it should in the standalone version. It is only the vst that gives the error message.
Things I have tried;
* Change the USB cable and port on the computer. Have usb sockets both front and back of the computer. Tested these and different cables.
* Tested running the editor via the e-mu8xl interface instead.
* Reinstalled the editor.
* Reinstalled the midi driver. It shows up in device manager just as it should.
* Tested in reaper 7 and reason 11. No difference. However, I have never run the vst in either reason or reaper before so I don't know if it ever worked with these daw's.
* Also tested in Live 12 beta but no difference.
Anyone have thoughts on this?
It's actually fine to use midi cc if you want to automate something but I really like the editor and especially the patch library.
