Did you know that you can overdrive the filters with the external signal loopback? And it sounds amazing.
1. Connect one of the Sub outs to the External Audio (EA) line input.
2. Mixer extended settings: route the EA signal from the EA line input to one of the filters
3. Output extended settings: you may need to add more boost to your Sub outs, to hear the overdrive.
