Ableton 12 & Sub 37 Midi Preset Issue
Everything Sub.
chrstnjms
Post by chrstnjms » Sat Mar 16, 2024 5:58 pm
1st moog, 1st post :) Please Help!
I load a preset, Its connected USB so I record a 8 bar midi loop. When I playback the recorded clip, the first part of the clip seems to change something, which I can tell from the 4 asterisks on the screen on the sub 37. I can't hear anything so its def changing something, but there is no recorded midi information in the clip in ableton. I have switched on / off every setting and nothing helps. There is no recorded prgm change data either.
If I select a different preset in the middle of the loop and switch back to the one I want it plays fine, but as soon as it loops around it changes something again and silence.
Really frustrated. Any help is much appreciated.
