Moog Mariana v1.0.1 Crash Report
Share Model D, Model 15, Animoog and Filtatron tips and tricks. Unleash your creations on the world.
flyset
Post by flyset » Tue Dec 19, 2023 5:47 pm
Hey moog developers,
just want to reporting some crashes I had observed with Mariana. Those happen mostly when Live tries to show the UI while it is busy doing other stuff eg. While playing some arrangement and trying to open the mariana UI.
You can see in the crash logs BAD_ACCESS while trying to access the JUSE::ComboBox, probably trying to rebuild it. I don't know I'm just guessing.
MacBook Pro Apple M2 Max
OS: Ventura 13.2.1
DAW: Ableton Live 11.2.10
AU Mariana v1.0.1
CrashLog:
Crashed Thread: 0 MainThread Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000ccce745c0e10 -> 0x00004cce745c0e10 (possible pointer authentication failure)
Exception Codes: 0x0000000000000001, 0x0000ccce745c0e10
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [50051]
VM Region Info: 0x4cce745c0e10 is not in any region. Bytes after previous region: 83968562826769 Bytes before following region: 21103517102576
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
commpage (reserved) 1000000000-7000000000 [384.0G] ---/--- SM=NUL ...(unallocated)
---> GAP OF 0x5f9000000000 BYTES
MALLOC_NANO 600000000000-600008000000 [128.0M] rw-/rwx SM=PRV
Thread 0 Crashed:: MainThread Dispatch queue: com.apple.main-thread
0 Mariana 0x2e898b61c juce::ComboBox::getSelectedId() const + 28
1 Mariana 0x2e86dcdb0 MMJuceComboBox::update() + 500
2 Mariana 0x2e86dcdb0 MMJuceComboBox::update() + 500
3 Mariana 0x2e86ddc0c MMJuceComboBox::dismissAllActiveMenus() + 88
4 Mariana 0x2e87bfab0 SectionDetailsMod::setVisible(bool) + 16
5 Mariana 0x2e87a6300 MarianaEditor::MarianaEditor(MarianaProcessor&) + 19424
6 Mariana 0x2e881ef98 non-virtual thunk to MarianaProcessor::createEditor() + 36
7 Mariana 0x2e85d12d8 JuceAU::JuceUICreationClass::uiViewForAudioUnit(objc_object*, objc_selector*, ComponentInstanceRecord*, CGSize) + 240
I hope it helps, or not... Anywayz.
All the best and nice holidays!
_ Kosta
javiereloymartinez
Re: Moog Mariana v1.0.1 Crash Report
Post by javiereloymartinez » Fri Jan 19, 2024 5:38 am
I sure love the Moog Mariana plugin, but it also keeps crashing my DAW (Live 11) and I don't have many patience left. :(
ultram
Post by ultram » Fri Mar 15, 2024 4:36 am
Would love to buy, still in demo but with constant crashes Live 12 M1 Monteray I'm hesitant
0 Mariana 0x35a326560 SectionDetailsMod::setVisible(bool) + 156
1 Mariana 0x35a32651c SectionDetailsMod::setVisible(bool) + 88
2 Mariana 0x35a308fe4 MarianaEditor::switchToSidePanel(MarianaEditor::SidePanels) + 372
3 Mariana 0x35a314ce4 OutputPanel::sliderDragEnded(juce::Slider*) + 684
4 Mariana 0x35a531b1c juce::Slider::Pimpl::sendDragEnd() + 204
5 Mariana 0x35a52f5d4 juce::Slider::mouseUp(juce::MouseEvent const&) + 348
6 Mariana 0x35a4a8b98 juce::detail::MouseInputSourceImpl::setButtons(juce::detail::PointerState const&, juce::Time, juce::ModifierKeys) + 720
7 Mariana 0x35a4a7f48 juce::ComponentPeer::handleMouseEvent(juce::MouseInputSource::InputSourceType, juce::Point<float>, juce::ModifierKeys, float, float, long long, juce::PenDetails, int) + 380
8 Mariana 0x35a4a3138 juce::JuceNSViewClass::asyncMouseUp(objc_object*, objc_selector*, NSEvent*) + 128
9 Foundation 0x1b2429f34 __NSThreadPerformPerform + 212
10 CoreFoundation 0x1b1524ec4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 28
11 CoreFoundation 0x1b1524e10 __CFRunLoopDoSource0 + 208
12 CoreFoundation 0x1b1524b10 __CFRunLoopDoSources0 + 268
13 CoreFoundation 0x1b1523490 __CFRunLoopRun + 828
14 CoreFoundation 0x1b15229b4 CFRunLoopRunSpecific + 600
15 HIToolbox 0x1ba168338 RunCurrentEventLoopInMode + 292
16 HIToolbox 0x1ba167fc4 ReceiveNextEventCommon + 324
17 HIToolbox 0x1ba167e68 _BlockUntilNextEventMatchingListInModeWithFilter + 72
18 AppKit 0x1b408b4b8 _DPSNextEvent + 860
19 AppKit 0x1b4089db0 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1328
20 AppKit 0x1b407bf7c -[NSApplication run] + 596
21 Live 0x103d39c94 0x102b50000 + 18783380
22 dyld 0x10a20908c start + 520
