[Answered] MAVIS - Sample & Hold is inverted?
Almost Aviation
Post by Almost Aviation » Thu Nov 30, 2023 6:44 am
Deleted - probably user error in connecting my Korg oscilloscope :)
Last edited by Almost Aviation on Fri Dec 01, 2023 7:15 am, edited 2 times in total.
MarkH
synthpeter
Re: MAVIS - Sample & Hold is inverted?
Post by synthpeter » Fri Dec 01, 2023 3:20 am
Not sure what kind of scope you're using, but here's what comes to mind to check first:
- if you're using separate probe cables, each with 2 clips, make sure that the probes both have the same ground and one is not swapped
- depending on the scope's capabilities, make sure that you've not set it up in a previous session to invert one of the inputs
Almost Aviation
Post by Almost Aviation » Fri Dec 01, 2023 7:08 am
Thanks for the reply. I think you are probably right that this is about the way I am monitoring. I am using a Korg NTS-2 oscilloscope and I now see I am getting different results depending on what cables I use! Unfortunately the Korg has two stereo inputs instead of four mono ones, and it looks like I may not be connecting my inputs properly :(
MarkH
