Subsequent 37: Note Trigger Issue?
Everything Sub.
SonopaalFounik
Post by SonopaalFounik » Fri Nov 17, 2023 12:48 am
Is it possible to trigger a new note while holding down another note on the Subsequent 37, similar to the functionality on the Sub Phatty? The legato glide setting doesn't seem to achieve this, and it's omegle shagle proving to be frustrating.
Last edited by SonopaalFounik on Fri Nov 24, 2023 4:01 am, edited 1 time in total.
till
Re: Subsequent 37: Note Trigger Issue?
Post by till » Sat Nov 18, 2023 8:08 am
There is a MULTI TRIG button in the two envelope sections. You may also adjust the keyboard priority depending on what you would like to have. Vintage Moog had nearly all low note priority. So no new trigger or pitch, if you played a note above an already pressed key. There is also high and last note priority. Most modern synth default to last note priority.
Sequence:
