One of my 4 Slim Phattys in Poly Chain always sounds Ring Modded
Everything Phatty.
thedutyfreedom
Post by thedutyfreedom » Tue Aug 29, 2023 11:05 am
Dear Forum,
I am a proud Slim Phatty poly chain owner. After some time setting it up it seemed to work perfectly, all parameters interact with each other and in general the system works.
However, my host slim phatty is the only one of the 4 causing problems. It always sounds some kind of ring modded/dissonant in itself. Slim phatty No. 2,3,4 always sound coherent. With the most presets that I change, the host Slim Phatty sounds off and it's not possible to solve it by fine tuning. What can I do about this? Like this, the 4-voice poly chain is not ready to use for most presets. I'm afraid something might be broken in the machine itself after such a long time not being able to figure it out.
I filmed it so you can get an impression:
https://youtu.be/JIJztSvBQR4
I would be glad if somebody of you has an idea.
Warm regards,
Nic.
readymedia
Re: One of my 4 Slim Phattys in Poly Chain always sounds Ring Modded
Post by readymedia » Fri Nov 10, 2023 6:22 am
Hola Nic!
Just check this maybe: https://www.youtube.com/watch?v=pN-BBuaJP1E
So it can be that two Phattys fire at the same time. Rich solved it somhow with Firmware update (DANGEROUS!!!) and chanching the order of Phattys...
More about here:
https://richsstudioproject.wpcomstaging ... a-prophet/
and here
https://richsstudioproject.wpcomstaging ... -fun-v1-1/
Best!, Ready
Former Mother 32 user ~ Now I have a broken Slim Phatty ;)
