Matriarch suddenly playing an octave lower?
Dhamaryder
Post by Dhamaryder » Sun Jul 30, 2023 1:40 pm
Hi, I just got the Matriarch yesterday and am learning it today. I was following a YouTube tutorial on the sequencer. Suddenly the synth is playing an octave lower. All oscillator settings are at 8’. I cannot figure this out but I’m wondering if I inadvertently got into Global settings somehow. I was using Hold(which I didn’t realize was the shift button) and had Sync Enable pressed just because the guy in the video had it pressed. So, I’m following along in the video and realize my synth is playing an octave lower. I could see in the video that his oscillator settings were also at 8’. I’m order to duplicate what he was doing I had to play everything and octave higher than he was. Does anyone have any idea what happened and how I can get it back to normal pitch?
Thanks for any help.
Steve
pmumble
Re: Matriarch suddenly playing an octave lower?
Post by pmumble » Tue Aug 01, 2023 11:12 am
Did you shift the octave down with shift-play? Perhaps all you need to do is press shift-tap to bring it back up an octave?
jazzy william
Post by jazzy william » Thu Aug 03, 2023 4:10 am
If a Matriarch synthesizer is suddenly playing an octave lower than expected, there could be several potential reasons for this issue. Here are some common troubleshooting steps to identify and fix the problem:
Check Octave Switch or Transpose Settings: Verify that the octave switch or transpose settings on the Matriarch are set correctly. Sometimes, accidentally adjusting these settings can cause the octave shift.
Modulation Sources: If the Matriarch is being controlled by external MIDI or CV sources, check if any modulation sources are affecting the pitch, causing it to play an octave lower.
Calibration: Ensure that the Matriarch is properly calibrated, as incorrect calibration can lead to pitch discrepancies.
Check Cables and Connections: Verify that all cables and connections are secure and functioning correctly. Faulty cables or loose connections may affect the pitch.
Factory Reset: Consider performing a factory reset on the Matriarch to restore its settings to default. Refer to the user manual for instructions on how to perform a factory reset.
Firmware Update: Check if there are any firmware updates available for the Matriarch. Updating the firmware can sometimes address bugs or software-related issues.
Contact Support: If none of the above steps resolve the problem, it's best to contact Moog Music (the manufacturer of the Matriarch) or an authorized service center for further assistance.
Remember, troubleshooting complex electronic equipment like synthesizers can be challenging, and if you are unsure about performing any of the steps, it's always best to seek help from a professional or someone familiar with the specific synthesizer model.
