Hi
One of the 921b's on my model 15 has suddenly started doing random pitches or warbling when I move the octave switch.
The 921b next to it is fine.
Any ideas what might be causing that ?
Thanks.
Model 15 Oscillator warble
- PaulLawler
- AlakaLazlo
Re: Model 15 Oscillator warble
Sorry you are having so much trouble with your 15. I had 2 thoughts. The switch itself may be failing. a squirt of Deoxit may help. Make sure the edge connector on the back of the module is fully seated.
Moog IIP, One 16V and MiniMoog, DotCom/FSFX/Moon/STG 110, Cubase 12Pro, Ableton Live 10/64, RME UFX+, 2xMR816, MioXL, Expressionist, Cirklon, Analog Rytm Mk II, Axon AX50, Customized Variax JTV69s (the Hexstainocaster), Strat, Godin ACS Slim, Helix.
- PaulLawler
Yeah it's definitely the octave switch because basic things like blowing on it helped a bit - put even different finger pressure on the switch can bend the pitch. I'll try this spray first and then I guess it's off to the tech.
