I am using a fully updated Moog Minitaur with the Minitaur Editor in Ableton and can't seem to automate the editor parameters. I explain more below.
For example, when using the editor, and MIDI notes are being played by the Minitaur, I can change the filter in real-time with the editor using my mouse.
I then expected to be able to simply draw in automation for the filter cutoff and it would work in the same way, just automated from the inputs - screenshot (example) to show this below. But, this automation does not change the filter cutoff and I am not sure why and if there is a solution to this.
I have tried using the clip envelopes - automating parameters from there and it works OK, but I prefer not using this method, as I like to create LFO chains and linked parameters in a way that I don't know how to do with clip envelopes - a simple example is using a (changing) LFO to control cutoff.
Is it possible to automate Moog Minitaur editor in Ableton Live?
