I have a Matriarch, running in 4 note paraphony, and when I hold down the sustain pedal and press a note to drone while i play other notes on top everything cuts off after about 124 notes. Anyone else experience this? I believe I’m running the latest firmware, having just done an update fairly recently.
It feels like a bug, but if it’s just a limitation so be it…
G
Sustain cutting off all notes?
Re: Sustain cutting off all notes?
You might try changing the global setting for keyboard priority. I think last-note priority is default, and it would need to keep a (limited) queue of pressed/sustained notes to work properly. Maybe, for your situation, low note priority would work differently. But maybe not in the way you want.
