Minimoog Model D iPhone App: Problem with 3-finger gestures
Share Model D, Model 15, Animoog and Filtatron tips and tricks. Unleash your creations on the world.
thecalimaki
Post by thecalimaki » Thu May 18, 2023 10:14 pm
[*][*][*][*][*]Hi there, I’ve emailed [email protected] about this 2 weeks ago but haven’t received a reply.
I’m using an iPhone 14 Plus running iOS 16.3.1. I have no problems using the official Minimoog app in standalone mode, but the problem occurs when I use it as an audio unit in AUM. When in the default mode, I’m able to play three-note chords properly, but once I press the switch to enlarge the keyboard, three-finger presses now bring up the undo/redo menu. I’ve tried other audio units, such as the Moog Model 15, and none of them exhibit this behavior, at least on a consistent basis.
I think this is an iPhone specific problem, as the undo/redo menu only appears after I toggle the switch to enlarge they keyboard (as seen at 0:26 in the video), which I don’t think you can do in the iPad version.
It’s also worth noting that in Garageband, going to the home screen and back is able to permanently solve this issue for that specific instance of Model D. No luck with that on AUM so far.
Any help would be appreciated.
[https://youtu.be/EsV0P5SO3Iw][/https://youtu.be/EsV0P5SO3Iw]
