Hello!
I recently acquired the moog sound studio trio, and I'm in the process of incorporating into my existing system.
I'm sending clock and notes over mid from a deluge into the mother 32, and then clock out from M32 via assignable out into subh, and from there into dfam.
This works, except that run I start on the deluge, it plays the M32 sequence, which I do not want. I want to sequence the M32 from the deluge.
So I learned that after updating to v2 of M32 firmware, I can achieve this by toggling step 2 (Follow MIDI Start Stop (On / Off) on page 8 of setup.
And it works! It no longer engages the M32 sequence when I hit play.
However when I do this, it no longer sends clock out of M32 to the subh.
Any ideas what I'm doing wrong so that I can send midi and clock from deluge into M32 without running the M32 sequencer, and still send clock on to subh(and then dfam).
Thanks in advance for any ideas!
Mother 32 clock sync stops working with page 8 step 2 turned off
