Help! Continuous note playing…
Posted: Thu Mar 30, 2023 8:28 pm
by iversonnr
There is a D that is consistently playing across all presets, and does not seem to be related to a physical key because the same note is playing regardless of whether I switch the KB octave. It also doesn’t seem to be midi related because I’ve unplugged it from MIDI and turned off ingoing and outgoing midi as well as local control and no change. Before just taking it into a shop, wanted to see if others have ideas of what I might be missing. Thanks in advance!
Re: Help! Continuous note playing…
Posted: Fri Mar 31, 2023 4:24 am
by MrChumley
If you’ve got a hanging note you need to either press the relevant key to get a note off or send a midi reset (all notes off) from your DAW. If the note plays all the time it will likely be a hardware issue.
Posted: Wed Sep 27, 2023 12:48 am
by charlescavalier
welll,... I think you should check for stuck or hanging MIDI messages. Although you've mentioned disconnecting the MIDI connections and turning off incoming and outgoing MIDI, it's still worth double-checking if there are any hanging MIDI messages. To do this, reconnect the MIDI cables and observe the MIDI activity on your computer or MIDI interface. Look for any sustained or stuck MIDI note messages being sent from the synthesizer. If you notice any, try sending an All Notes Off message (MIDI CC 123) to clear any hanging notes. :D
Posted: Tue Jun 18, 2024 6:13 am
by cadgesneaky
It's still important to confirm that there are no dangling MIDI messages, even though you indicated unplugging the MIDI connections and turning off incoming and outgoing MIDI. Reconnect the MIDI cords, then watch the MIDI activity on your computer or MIDI interface to accomplish this. geometry dash lite
