New Matriarch Velocity Curves incorrectly described
Posted: Tue Mar 14, 2023 6:17 pm
The patch notes say:
To test the different curves, I patched velocity to the pitch of osc 1 via an attenuator. By holding a note with full velocity and then adjusting the attenuator to pitch the note up exactly 1 octave, it's easy to test out the different curves by e.g. trying to play a scale just by varying velocity. Until I tried the COMPRESSED setting I had given up on the firmware update actually helping things.
Hope this helps someone, also if anyone can shed more light on this would be interested to hear.
My issue has always been that the velocity curve is too sensitive in that I can't play anything soft unless it's literally "Velocity 0" - play a bit harder and it jumps to almost full. So it sounds from the above that LINEAR or STRETCHED would help me. However, actually it's COMPRESSED (F4) that has made it easier for me to produce the full range of velocities, by making it more physical effort to produce high velocity values.HIGHLIGHTS
With new global setting 5.3 you can switch between four different velocity curves. If you tend to play keys with a harder
touch, try switching to LINEAR or STRETCHED to more easily produce softer velocity values. Alternatively, switching to
COMPRESSED will make it so that higher velocity values are produced with less physical effort.
