Hi there,
the manual of the Claravox Theremin says (p. 48):
"CV In (Expression Pedal Input)
An external control voltage connected to this jack can change the value of the assigned parameter. The default parameter is the Front Panel FILTER knob. This assignment can be changed via the Claravox Centennial software."
In the software I found settings for CV scale, offset and voltage range, but I couldn't find any way to change the assigned parameter for CV-in. Do I miss anything?
Cheers
Synthfluencer
