Wondering if there are any Rogue tech experts out there, basically I was doing some maintenance work and decided to recalibrate the Osc on my Rogue only to realize that Osc 2 is way out of range. I think I had been using them in sync mode for a very long time so I hadn't noticed, but in following the manual, I can't get it to calibrate properly. I was able to get Osc 1 without a problem, but 2's range is way off, it sounds fine when in sync mode but when its on its own it I just can't even get it close without running out of turns on the trimmers. Any suggestions? Any parts to check in general?
Thanks for the help.
Barry
