Unison In Init Patch
Posted: Sat Nov 19, 2022 2:52 pm
by eltobosolo
Hi All,
Maybe this has always been happening and I never noticed... but when I load the init patch, it seems that there is some sort of unison mode with 4 voices going on. That is, when I press a single key, I can see 4 voices are used even though I don't have unison mode on. If I set mono mode on then only one voice is used. Is there a setting somewhere that I don't know about?
Re: Unison In Init Patch
Posted: Sun Nov 20, 2022 12:24 pm
by till
Disconnect all USB and MIDi cables and try again? Is it better? If yes, you got some MIDI loop.
Posted: Sun Nov 27, 2022 6:39 pm
by eltobosolo
You nailed it - thank you!
Posted: Mon Nov 28, 2022 5:45 am
by till
If you use the original setup, set the Moog One to LOCAL OFF mode. It should work this way with DAWs
