Could someone, please, answer -
Is it possible to calibrate Werkstatt-01 (w/ CV Expander)
with Arturia Beatstep's (not the pro version) pitch and gate outputs?
How to establish which C note and octave from Beatstep
is sending 0V to Werkstatt?
Thank you!
Calibrate Werkstatt-01 with Beatstep
Re: Calibrate Werkstatt-01 with Beatstep
gr00veh0lmes wrote: ↑Wed Sep 07, 2022 8:24 am The calibration procedure for the Werkstatt worked the same for the Mavis.
Note: This was done while Mavis was in an initialised setting (pitch knob at 12 o clock).
1. Determine 0 Volts on your controller, for my Keystep it was C-2. This can be confirmed by the pitch remaining constant while you adjust the Pitch Calibration screw.
2. Dial in the correct pitch (C in this case) using a tuner and the pitch control on the front panel.
3. Shift a few/several octaves up on your controller, play the same C and adjust the Pitch Calibration screw until the tuner shows a C.
You can confirm the above steps by playing C’s between those in steps 1 & 3 to finesse your results.
Video description here…
https://youtu.be/vVNI3jibZ4U
