foogers with LP knobs
Posted: Tue Oct 31, 2006 2:11 am
what ever the next fooger is they should do this for it.
imagine a normal moogerfooger that uses the LP knobs (with the ring of LEDs) for each of its four performance parameters. the LED indicates the value of the parameter in respect to the knob position and whatever CV signal is driving that value. so if you don't have anything plugged into the CV in for that parameter, then it just follows the knob but if (while your playing guitar) you sweep an expression pedal that's plugged into it, you'll see the LED move up and down to show the change! or LFOs from the cp251 or any CV singal!
it would probably add an extra few hundred to the cost but....it would be pretty cool!
