MIDI sync - Arpeggiator problem
Posted: Sat Mar 05, 2022 8:02 pm
Hi!
I have managed to get the arpeggiator on my sub 37 to sync with logics bpm, but when I try to record an arp with latch mode on, it repeats only one note of the chord I am arpeggiating. All notes arpeggiates when im holding down a chord, however, when im releasing the keys in latch mode, it just repeats one note of the chord.
My setup is: Sub37 audio out > channel 1 input (Rubix44). I have a midi cable going from Rubix44 midi out > Sub37 midi in, and a second midi cable going from my Sub37 midi out > rubix44 midi in. I have also tried to connect the sub37 to my computer with USB cable, but the problem still persists.
In logics midi clock destination 1, I have only this option > (Rubix44)
For the (mode:) I have tried to set it to both "Song - SPP at Play Start and Stop/SPP/Continue at Cycle Jump" as well as "Pattern - Quantized clock start based on pattern length"
In the Sub37´s internal MIDI MENU, I have "in channel" set to 1, and "out channel" set to 1. In the Sub37´s internal clock options I have "send clock" set to "ARP" (I also have the option to turn it off or on), and I have "send st/stp" set to on, and "Follow spp" set to on.
I would greatly appreciate your help if you have any ideas on how to solve this
